How to generate mixed trigger signal
Hello, how to generate a trigger signal with two different width pulses like this, by using a daq card? Thank you!微信截图_20230730122859.png
(964 Views)
You can use digital waveforms.
What is the desired pulse width for both big and small pulses?
What is the model of the DAQ device you have? Most multifunctional DAQs only support digital waveform timing of up to 1MHz.
https://tmesystems.net/
(929 Views)
If your device supports it, you could also generate a buffered pulse train with a counter task, which would give you finer resolution for your time intervals.  X-series MIO devices and newer cDAQ chassis support this feature.   (But there are *more* devices that would support a digital waveform.)
-Kevin P
(922 Views)
