How to generate several different waveforms on different channels
I want to generate 4 different waveforms on 4 different channels synchrounously on an external trigger. How can I archieve this
with WFM_OP?
thx for help
Brickwalker
(2,981 Views)
Are your channels on the same device, or different devices? If they're on the same device, then you'd just use one call to WFM_Op. If you're using multiple devices, you can't use WFM_Op, because it is a synchronous function. You'll have to use the lower-level WFM_Load & WFM_Group_Control asynchronous functions.
--Joe
(2,978 Views)
