How to get DAQ card-516 working in LV8.5
Hi Ning,
I understand that you are now able to see your DAQ palette in LabVIEW 8.5, but you are having trouble with MAX. Do you still have MAX installed on your computer? You should be able to use the latest version of MAX with NI-DAQ 6.9.3 without having to uninstall it or reinstall an older version. Can you try placing the MAX folder back where it was and seeing if you can run MAX?
What I tried out was to install LabVIEW 8.5.1, then install the latest version of DAQmx (which also installed the latest version of MAX). When I uninstalled DAQmx 8.7.1, MAX 4.4.1 remained on my system. I then installed the LabVIEW 6.1 RunTime, followed by NI-DAQ 6.9.3. The only item I chose to include support for when I installed NI-DAQ 6.9.3 was LabVIEW 6.1, only I changed the target directory to be my LabVIEW 8.5.1 folder. Using this method, everything worked fine, and I was able to detect everything properly in MAX and LabVIEW. Overall, it seems like you have things working properly with the legacy driver and LabVIEW 8.5, but that you are simply having trouble running MAX. I am not really sure why you had to move MAX from the National Instruments folder, but try and see if you can move it back and get it working properly that way. You should not have to uninstall this newer version of MAX. Hope this helps,
Daniel S.
Message 11 of 12
(872 Views)
Hi Daniel,
I just figured out my probelm a moment ago. What I did is exactly the same as you suggested! Newer version of MAX is compatible with NIDAQ 6.9.3 in LV8.5. I don't have to uninstall MAX 4.3.
Thanks a lot! Sweet dream!
Ning
Message 12 of 12
(870 Views)
