How to get PCI DAQ serial no witout using daq mx drivers
  I am using Ni PCI DAQ 6024E, I want to read my DAQ serial no, I already done using daq mx device property. It is possible to read the daq mx serial no without using daq driver functions and how to do?
Thanks in advance
Balaji(CLAD)
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(2,942 Views)
Hey,
I would like to refer to the DDK Board (http://forums.ni.com/ni/board?board.id=90) where you might get a solution of this with Register-Level-Programming.
Christian
(2,886 Views)
