How to get file from a virtual channel?
Hi!
I'm new using Labview. I have a DAQcard-AI-16E-4 and Labview 7. I'm using some K thermocouples and I need to do some temperature measurements. So far I have been able to get a chart; but I just cannot create a file with my measurements. What can I do? Thank you = )
(2,600 Views)
You can find an example that does that in LabVIEW => Help => Find Examples (The NI Example Finder window will open) => in the Browse Tab go to Hardware Input and Output => Traditional DAQ => Analog Input => Stream to Disk and finally double click on Cont Acq to Spreadsheet File.VI.
Please let me know if you had problems finding this example.
LA
(2,589 Views)
