How to get rid of the periodical spikes on the sinwave voltage output from NI USB 6251
Hi Expert,
I am writing a program in Labview, aiming to generate a sum voltage signal (a ramp voltage plus a sin wave voltage) from NI USB 6251.
In the program, I could get clean signals, but when I check the voltage signals with scopes (three different scopes), the sin signals are corrupted by periodic spikes (40 KHz, 25 us) all the time. Then I unplugged the DAQ from the computer, checked the output from the DAQ, the spikes are still there.. So I think the spikes must come from the DAQ. How to get rid of them?
Thanks very much!
(4,142 Views)
Hello Memorysun,
In most Analog output applications (DAC tasks) glitches (spikes) are generated. There are techniques to reduce the  glitching which are outlined in this link http://digital.ni.com/public.nsf/allkb/9B13E25B0B0EC197862562B4007D2E33?OpenDocument. For glitch free tasks, you would need a dedicated Analog output card. Please refer to the usb 6251 manual below for the glitch energy information
http://www.ni.com/pdf/manuals/371291h.pdf
Regards
Will
William A
National Instruments UK
(4,125 Views)
Hello Memorysun,
I hope all is well. Can you please confirm if my previous post sheds more light on the problem and answers the question
Regards
Will
William A
(4,063 Views)
Just found:
Use an RC filter to 'deglitch' a DAC  Bonnie Baker, Texas Instruments -- EDN, July 28, 2011
Greetings from Germany
Henrik
LV since v3.1
(3,996 Views)
