How to install an USB6229BNC to be used as an IVI device under teststand?
I have to install an USB6229BNC on an Laptop running Win7 /64. This will have to be accessed under Teststand 14 as an IVI device. So what do I have to install in which sequence? And how will the device be accessed later in Teststand?
This is, what I tried until now:
The first part described in the help file was to install NIDAQ861. Having done that, I found the device in the Windows Device Manager. But no access in any way to the device was possible.
After installing NIDAQ1600f0 I found the device in the NIMAX, so my hope was, that I could start to setup the device as IVI. In fact I could start to edit the driver session, but on the software tab I stuck again, because the device wasn't specified in any way.
So I think, I need some help how to install which driver in which sequenceand where do I get the API to access the device after that.
Thanks in Advance
Regards Kai
(3,601 Views)
Accepted by topic author Eselchen
AFAIK there is no IVI class that would cover any DAQ device - http://www.ivifoundation.org/about/instrument_classes.aspx
You can use the USB-6229 in TestStand directly using the DAQmx driver with this toolkit: http://www.mesulog.fr/produits.php?art=3&lang=en
(3,560 Views)
Hello, Stockson,
thanks for the info... I was in the opinion having read this. I wonder, what I've missunderstood in the docu.
Thanks for the links, I'll try the toolkit.
Regards Kai
(3,547 Views)
