How to know the force (Newton), given a millivolt output?
Any Principles or Conversions?
Example:
30 mV = _______ Newton?
Pls Help
(18,420 Views)
Impossible to answer unless we know the output characteristic of your load cell / amplifier...
(18,418 Views)
so you mean it depends on the specification of that load cell like its load capacity and  output signal.....
Correct me if I'm wrong....plss
So if ive got a load cell that has:
max load capacity = 1250 kN
max output signal = 100 mV
so if ive got a measured output of 30 mV, then i will get a 375 kN force applied>?
30 mV * (1250 kN / 100 mV) = 375 kN..........
Plss confirm if im correct
thanks
~nievz~
(18,409 Views)
Your computation seems correct.
Is this a strain gauge load cell ? Has it an integrated electronic or do you use an external amplifier ?
With this type of load cells, the output rate is expressed in mV/V and the output depends on the sensor's supply voltage.
Could you provide the datasheet in order to remove any doubt ?
(18,386 Views)
Well this can be done actually. When you draw a graph of potential diffence, milivolt with respect to force, newton, you will find that 1 milivolt is equal to 100 newton.
(17,498 Views)
Could you help me please? or should I write a new topic?
regards
(6,630 Views)
regards
I'd recommend starting a new topic and add a lot more detail to describe your problem.
(6,623 Views)
