How to know the property in trouble when having error "Requested Value is not a supported value for this property."
I'm using LabWindows/CVI and when doing a DaqmxStartTask, I get the error : "Requested Value is not a supported value for this property."
This message was obtained by calling DAQmxGetErrorString with the status code returned by DaqmxStartTask.
QUESTION: Is there a way to know which property has an unsupported value ??
Thank you
(4,363 Views)
Which hardware do you want to use? What kind of acquisition do you try to realize?
Could you provide your code ?
Regards
Samuel G. | GEMESIS
Certified LabVIEW Architect
Certified TestStand Developer
GEMESIS.EU
(4,315 Views)
I'm using LabWindows CVI8.0.1 to generate some numeric data on a PCIe-6353. All configuration is ok (I mean configuration of channels, clocks etc.) but when I'm calling DAQmx_StartTask, I get the message "Requested Value is not a supported value for this property." and the task does not start.
=> Is there a way to know which parameter is not supported ?
Thx
(4,229 Views)
