I'm trying to figure out if its possible to lock the phase of analog input with a USB6009. I'm using the C++ API and the example files. I'm running a basic 50Hz sine wave into USB6009 and reading in values with the "Cont Acq-Int Clk" example. When I printf the first value - data[0] - the value will slowly drift. I'm not exactly certain how to lock onto this signal. Is this a triggering issue? I know the USB6009 doesn't have an analog trigger mode. Does anyone have any ideas?
Thanks and best regards,
Matt
