How to make a program for USB-6008 in Visual Studio C++ MFC without Measurement Studio?
I need some help to create a program for USB-6008 in Visual Studio C++ MFC. I have run the exampels file for ANSI C and that is working. But when I try to get USB-6008 to work in Visual Studio C++ MFC i get a lot of trouble.
I can´t use any of the functions i NIDAQmx.h then I only get this message:
MFC VOLT MESSURINGView.obj : error LNK2001: unresolved external symbol _DAQmxCreateTask@8
Is there anyone who can help me with this? Or is it impossible to use USB-6008 inVisual Studio C++ MFC?
If it possible please add some example code to!
Best Regards Anders!
(3,853 Views)
Hi Anders,
It sounds like you need to configure your Visual Studio C++ project to link your application against NIDAQmx.lib.  This library provides the entry points for each of the DAQmx C API calls.  If you do not link your application against the library, you will get errors like you describe in your post.
Hope this helps.
Aaron
(3,838 Views)
Thank you very much!
That was exactly the litlle thing I had forgotten!
Message Edited by olssoninc on 10-16-2006 12:26 AM
(3,826 Views)
Do you have any example code of program for USB- 6008 in Visual Studio C++ MFC.
I need some example to program for USB 6221.
(2,893 Views)
