How to modify Simul AI AO Buffered SW Trigger.vi?
I was wondiering if it is possible to modify Simul AI AO Buffered SW Trigger.vi to allow for a boolean start button to trigger the simultaneous analog output and analog acquisition or do I need to rewire the connector board (i.e. split the analog out signal to the PFI0 pin)? (PCI-MIO-16XE-1 and SCB-68) Thanks
(2,640 Views)
Tick,
It should not be too difficult to modify the example to include a start button. I have attached a modified version of the example. I think it has the functionality you have described.
Good luck with your application.
Spencer S.
(2,640 Views)
