How to output two pulse train using USB6501
Hi, now i has one NI device-USB 6501. and i want to generate two pulse train,one is for clock, the other one is data, the data should be triggered by the rising edge of clock.
My ideal is this:
1.Using Digital waveform editor to generate the two digital signal, and save them as a HWS file.
2.Load this HWS file using LabVIEW SignalExpress.
3.Output the digital signal using USB6501.
my question is how can i output the signals using USB6501.
Thanks for your attention,any help will be appreciated.
(3,208 Views)
Attached is a vi that puts out two synchronized waveforms on two digital output channels. It was developed for another application with different requirements, but you should be able to adapt it to do what you want. I don't know if the USB-6501 supports the clocked digital output because I don't have one.
Richard
(3,176 Views)
USB-6501 does not support correlated DIO.
Best Regards,
Tao Hou
NISH
(3,158 Views)
