How to read digital signal using NI6025e+NI PCI-1200 Adapter
Hi all, sorry to say that i'm new to DAQ card and i'm encountering a problem and i'm hoping someone can help me out. I'm using NI-6025e with PCI-1200 adapter, and i know these are products are quite old but no choice, i was provided with these equipment only.
I need use them to read digital signal from another peice of measurement tool. The measurement tool will give high bit of 5V and low bit of 0V and i need to use NI6025e with PCI-1200 adapter to read this digital signal.
I have to tap two wires from the output of the measurement tool to PIN 22 and PIN 13 (DGND) of the PCI-1200 adapter and i expect i will get the digital signal through my software. But i did not get any reading at all.
So may i know am i connected to correct PIN of the PCI-1200 adapter in order to read the digital signal?
Helps and advise are appreciated.
Thanks in advance.
(4,106 Views)
The PCI-1200 is a stand alone DAQ device and is not an adapter nor does it have any relationship to the 6025e.
The pin you are using is Port B bit 0 and should work just fine. What are you using to read the data at the pin? Did you specify the correct device?
(4,104 Views)
Hi Dennis, thanks for the reply. There is a adapter conversion for Ni-6025e and here's the infor :http://sine.ni.com/nips/cds/view/p/lang/en/nid/11027
I tapped one wire_A at Port B bit 0 (PIN 22) and another wire_B at PIN 13 (DGND). The first wire_A is come from digital output of my measurement tools and the wire_B is come from analog ground of my measurement tools. And when i check with multimeter by tapping the same point at my instruments too, it gives reading of 5V.
I'm using NI-6025E and my software is visual basic referenced with DAQ.dll. When i read input value using the DIG_In_Prt of port B, it's returning 255, it's correspond to 11111111, which meant all bit of Port B is high? But i do not connect to other bit except bit 0 of Port B.
So is my hardware connection correct?
Please advise..
(4,042 Views)
I don't see where the problem is. You've verified with the voltmeter that you have a logic high and that is what you are reading. Set the input to 0 volts and do a read.
You are using the function to read all bits of the port and if you have nothing connected, the inputs will float to a logic 1.
(4,030 Views)
Hi Dennis, what i meant here is when i tapping the output signal of my digital output of my measurement tool, it shows 5V which is high bit. So my measurement tool is giving the correct signal.
But i can't read the digital signal using my vb applications from the DAQ when my measurement tool is connect to the PIN22 and PIN 13(DGND). It's always showing 8 bit high (255). So my question is, can you please check is my wiring correct (by tapping the analog ground of measurement tool to my DAQ digital ground)?
Besides, i expect to read a value of integer 1 (00000001) when i connect my measurement tool to the digital pin of the DAQ card. How can i do that? Is it a must to connect all the 8 bits even though i'm just using a single bit?
Additionally, i can actually sending digital signal to control my measurement tool through the same DAQ and same VB applications through Port A.
Please advise and thanks in advance.
(4,017 Views)
I still do no see your problem. You should be reading 255 when pin 22 is connected to a 5V signal and the other pins of the port are not connected to anything. If you insist on using the Dig_In_Prt and want to read 00000001, then you would have to ground the unused pins. Otherwise, use the Dig_In_Line function for just bit 0.
You might also consider upgrading to DAQmx instead of the obsolete traditional DAQ that you are using now.
(4,013 Views)
Hi Dennis, i took your advise and i'm using Dig_In_Line to read single bit digital signal. When i try to ground the PIN 22, it's show 0 and when i'm not connect everything, it's always showing 1. And now i know there is nothing wrong with my software coding and it's just that i need to connect correctly in order to get the signal.
However, here comes my second questions. Let said i have voltage supply which given 5V when it's ON and 0V when it's OFF. I have tried to make a direct wire connection from the positive terminal of my voltage supply to this PIN 22 to and negative terminal to PIN 13 (DGND) of my DAQ.
But when i turn my power supply ON or OFF, it's always showing high bit of 1. Actually i just trying to stimulate the digital signal of high or low by supplying 0V or 5V.
So may i know what i can do in term of wiring in order to read the 0V and 5V as digital input? I just need a simple wiring connection that will works because i'll just using it for data collection.
Please help and thanks in advance.
(3,984 Views)
