How to read hall effect sensor signals?
I am trying to read a 2 leg (A & B )signal from a hall effect sensor on a DC motor. How should I bring this signal into a DAQ board and what board should I use? What connector block?
(3,333 Views)
You have numerous options available to you.
First, National Instruments has Motion Controllers. Below is a link to the product page for these products:
If you are interested in the Motion Controllers, I would suggest that you post a question to the Motion Discussion Forum linked below:
Since you posted your question to the Multifunction DAQ Discussion Forum, you may be interested in controlling your motor with a DAQ device. Again, this area also provides many options. The M-Series boards have analog input, analog output, digital I/O, and counter channels. It appears that you would need a digital I/O channel to turn the motor on/off and an analog output channel to adjust the motor's speed. Below is a link to the M-Series product page:
M Series Multifunction DAQ
Hope this helps!
LA
[Thread from Spencer S. updated]
(3,315 Views)
