How to read scxi-1120 modules in scxi 1000 chassis using NIDAQmx C functions?
I need to connect M6221 to a SCXI chassis containing two 1120 modules. Now it is not a hardware question but software. I did not find the way to read the signals from the modules via NIDAQmx C functions. Could anyone help me how to do that? (Traditional NIDAQ performed it very clearly...)
thanx
BLCL
(2,752 Views)
The programming style is just the same as without scxi. The only thing you have to do is configure the scxi chassi within Max and create a tsk using the scxi 1120 channels. Use the task within Analog Input ansi c example shipped with the driver.
(2,735 Views)
