How to relax the error step vi from memory when sequence file is running.
Hi
I have a parallel mode sequence running two sockets. There is a DAQmx AI step to acquire something, if the acquisition timeout, TestStand will popup the Run-Time error window for user selection, if I run next loop, the DAQ card is in use(the vi steps are all configed to dynamic loaded), so I would like to find some methods to relax or close the vi from memory. And then the vi will relax the hardware that will enable the card in next loop or another socket.
*The best Chinese farmer*
Message 1 of 1
(2,891 Views)
