How to select a longer time out to avoid error Error 200284
I am using USB6008 and I would like to get the best resolution of FFT from a volage signal.
As far I am able to go is to get 20 point in the FFT beetwen 40 and 41 Hz graph 10000 samples with 500 Hz sampling rate, but it keeps getting Error 200284. It say I should select a SignalExpress longer time out. How can I select a longer time out in the SignalExpress ?
(3,062 Views)
You can increase the timeout under the Advanced Timing tab on the Acquisition step.  On this tab under the section called Additional Timing Settings you can increase the Timeout to a higer value.  If you set the timeout to -1 the acquisition should never timeout but will wait indefinitely for the acquisition to complete.
Neil S.
(3,053 Views)
