How to set the serial number of simualted device?
Is there any way to set the serial number of simulated DAQ devices?
Right now we end up with multiple devices with the same serial # (always 0) which casuses problems for our existing code that partitions the cards by SN (as opposed to the new ability to name the cards).
(2,933 Views)
You won't be able to set this. For a simulated device, data that is normally stored on the physical device, such as serial number, is always returned as 0.
I believe the only way you can resolve this is to hard code the serial number when testing your application.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(2,919 Views)
