How to simulate the loop powered or Active or Source Analog Input device through NI?
We have loop powered or Active or Source Analog Input Current device. we need to simulate input signal through NI for Automation. We are not getting any Sink Analog Output Current Card from NI. Please suggest anyone has any idea. we are looking for the CDAQ or PXI card I have attached our system diagram/user manual.
(2,422 Views)
Hi sumit,
If you are looking for a current output module you can go with NI 9265 or NI 9266. These are c series modules which fit in a cDAQ chassis. For instance, NI 9266 has 8 analog outputs and can output current at a maximum rate of 24 kS/s/ch. For further details please refer to the datasheet of NI 9265 and 9266 which is attached below.
https://www.ni.com/docs/en-US/bundle/ni-9265-specs/page/specs.html
https://www.ni.com/docs/en-US/bundle/ni-9266-specs/page/specs.html
(2,155 Views)
