How to synchronize PXI-6224 and PXI-5122 with PXI-5401 signal generator?
There are PXI-5122 digitizer,PXI-6224 DAQ and PXI-5401 signal generator.In MAX,5122 and 6224 are DAQmx devices,but 5401 is a traditional DAQ.
I want 5401 to generate a triangel waveform.When it starts,6224 and 5122 start acquisitions at the same time.
I use niFGEN Route signal out.vi to route OUT START TRIGGER to a RTSI line,and set this  PXI_Trig line as the trigger sources of 5122 and 6224.
Is it right?
Sometimes it works fine,but sometimes it fails.Is any problem in my block?
Thanks.
Windows XP SP2+LabVIEW 7.1
Message 1 of 1
(2,943 Views)
