06-17-2008 04:14 PM
06-17-2008 04:26 PM
06-18-2008 04:38 PM - edited 06-18-2008 04:39 PM
Hi Fuh,
I would recommend creating an AO task and use the export signals VI to send the internal start trigger out to one of your PFI lines. This will create a TTL pulse on whichever PFI line you specify at the moment the task is started.
06-21-2008 09:05 AM
07-02-2008 02:18 AM
Hi Fuh,
I am using Labview 7.1 with vista and USB6009. I am gonna record the EEG signal and display it on the Labview. But, I do not know how to do it. Can you help me?
Orchid (cruel_orchid@yahoo.com)
07-02-2008 04:45 PM
Hi Orchid,
Since this thread is about a different topic that has been solved, I would recommend starting a new thread under the Multifunction DAQ forum. This way you can get the fastest response from frequent viewers. Thanks and have a great day.
