How to syncronize two data acquisition boards?
I would like to know how I can use two Multifunction Boards simultaneously? For example, I had two NI6024 boards and I would like to use 16/DI channels. I want to syncronize them. Thank you.
(2,671 Views)
Youngkey,
You can synchronize the two data acquisition boards, by using the RTSI bus that is part of the architecture of the boards. I am attaching the text of a Knowledge Base which describes how to accomplish this goal:
Title:
Synchronizing data acquisition between two or more MIO-16 series boards
Problem:
How can I synchronize data acquisition between two or more MIO-16 series boards?
Solution:
First, place a special Real-Time System Integration (RTSI) cable on the RTSI connector. Then, determine what trigger pulse signals need to transmitted to the trigger inputs of each MIO-16 series board. The board which sends the trigger signal becomes a 'master' and the board that rec
eives becomes a 'slave'. Finally, start the data acquisition on both boards. Make sure you call the data acquisition functions or VIs on the slave board first to arm the acquisition. Below is a list of necessary function calls.
* In NI-DAQ or LabWindows: Call the function RTSI_Conn for each counter or trigger signal you wish to connect up to a RTSI Trigger Line. Then call the regular functions to perform a data acquisition on both boards. Call the function RTSI_Clear at the end of the program.
* In LabVIEW: Call the RTSI Control VI with control code set to Connect for each counter or trigger signal you wish to connect up to a RTSI Trigger Line. Then call the regular VIs to perform a data acquisition on both boards. Call the RTSI Control VI with Control Code set to Clear at the end of the program.
Hope this information is helpful.
L Aguila
(2,671 Views)
