How to use digital ouptuts
I am new to labview. In my application, I have two select lines based on which sensors are selected. Inorder to select particular sensor I have to output 5v to digital output lines. How can I do that?? I have tried sending the boolean True or False to the digital outputs. But it dnt work.
Thank You in advance.
(3,279 Views)
Sorry, I forgot to mention that I am using USB 6211.
(3,277 Views)
Did you configure the task?
Does it work in test panels?
Posting the code you've got will help diagnose and troubleshoot the problem.
(3,274 Views)
Yeah, I have tested it in MAX. If i just input the boolean then its not working. I have taken the screen shot of my code. I am using DAQ assistant to generate digital output for every 1000secs.
(3,272 Views)
If you are going to attach a png, at least make it a snippet (look it up). Cannot run or debug an image.
You do not mention what the digital lines are connected to. Disconnect them and try testing in MAX again.
(3,269 Views)
