How to use more than one USB 6453
We have bought one mioDAQ USB 6453 for use in a logging application to try it out. But in total we have 44 differential signals that we would like to log. Is it then ok to use 3 pieces of USB 6453? How to connect to one PC?
Goran
(652 Views)
It should be fine if you use a Bus-Powered Hub
Refer to Example for Synchronizing two DAQ devices Using LabVIEW with DAQmx if you want to synchronize them.
https://tmesystems.net/
(629 Views)
Thank you for your reply! I will look into this
(616 Views)
