02-27-2006 05:37 PM
02-27-2006 05:45 PM
Hi all,
this is the continuation of my previous post. i want to know the same thing for output tasks as well. in otherwords, is it possible to send two different signals through one channel? for example, with two create virutal channel vis, can i send AO voltage through one and counter output through another one?
thanks again
Rishe.
02-28-2006 12:05 PM
02-28-2006 12:06 PM
02-28-2006 05:34 PM
Hi Michael and all,
Thanks for your kind reply. I understand what you said except how to recall the create channel vi several times. is it should be in a while loop or something? same thing with output as well. i understand that a task could be of only one type. but if i want two different tasks should be done, what i have to do?
I will give an example. one of the main aims of this program is to drive a motor with an analog signal. at the same time, i also want an option of sending a constant voltage (may be in form of a pulse) to the motor so that i can change its initial position. so i was trying to use the counter output option as well. now it becomes two tasks. so how could i do this?
hope i make it clear this time. the attached program may clarify further.
sorry if my question sound obvious but i m using labview only for the past 3-4 months and i dont know much about it.
Thanks a lot.
Rishe.
03-01-2006 06:23 PM
03-02-2006 06:15 PM
Hi Michael and all,
Thanks for your response. The example you have given is very helpful. thanks for that. i think i can try the same thing for output tasks as well. i will try with myself first and if i couldnt i will come for your help once again. hope u dont mind. 🙂
thanks again
Rishe.
03-02-2007 09:44 AM - edited 03-02-2007 09:44 AM
Message Edited by UBAP on 03-02-2007 09:57 AM
Message Edited by UBAP on 03-02-2007 09:59 AM
03-05-2007 07:41 PM
