How to use three NI9237 modules with the DAQ-Assistent
Hallo,
I want to use three NI9237 modules to gauge strain with 12 strain gauge strips. But I don't know how to configurate the DAQ-Assistant with three modules. I just can configurate four channels of only one NI9237 module.
How can I add more channels to the DAQ-Assistent?
Thanks for the help
Philipp
(2,942 Views)
Hi Philipp,
I don't understand your problem. Because you don't give us further information, I think you use a cDAQ-chassis for your NI-9237 modules.
You can select more than only four input channel of one NI-9237 in the DAQ-Assistent, if you press the Shift-Key during the same time you select the channels.
See both attached pictures.
Regards, Stephan
(2,932 Views)
