How to wire two Turbidimeter Model 850 to one NI 9203 module (8 channels) ?
Hi all,
I am using NI cDAQ-9174 and NI 9203 analog current input module.  I want to use two turbidity sensor whose output are 4-20 mA.  I will wire the two negative lead of the turibidity sensors into one and connect it to the COM.  The positive lead of the turbidity sensor number 1 will goes to the AI0 and the positive lead of the turbidity sensor number 2 will goes to the AI1.  Am I correct?
The wiring diagram of the turbidimeter model 850 is attached below.
Thanks.
(3,476 Views)
Sounds rigth 🙂
Greetings from Germany
Henrik
LV since v3.1
(3,450 Views)
Thanks Henrik !
(3,443 Views)
Hi Tritran,
It looks like you already have an answer, but if you're looking for more information on 4-20 loops, we have an article that goes into a bit more depth on the topic: here's a link.
Kathryn K.
Technical Support Engineer
http://ni.com/support
(3,433 Views)
Hi Kathryn,
Thanks for sharing the paper.
(3,426 Views)
