How to you specify DAQmxRegisterEveryNSamplesEvent in C++ ?
Can you tell me what the syntax is for using DAQmxRegisterEveryNSampleEvents in C++?
I have tried to specify the following:
DAQmxErrChk (DAQmxRegisterEveryNSamplesEvent(
/*TaskHandle taskHandle*/ m_hTaskHandle,
/*int32 everyNsamplesEventType*/ DAQmx_Val_Acquired_Into_Buffer,
/*uInt32 nSamples*/ NI_DAQmx_SAMPLE_SIZE,
/*uInt32 options*/ 0,
/*DAQmxEveryNSamplesEventCallbackPtr callbackFunction*/ &NIDAQmx::OnEveryNSamplesCallback,
/*void *callbackData*/ NULL));
but I am getting the following build error:
error C2664: 'DAQmxRegisterEveryNSamplesEvent' : cannot convert parameter 5 from 'int32 (__cdecl NIDAQmx::* )(TaskHandle,int32,uInt32,void *)' to 'DAQmxEveryNSamplesEventCallbackPtr'1>
There is no context in which this conversion is possible
I also tried using a type cast and that did not resolve the error.
Thank you.
(3,633 Views)
It looks like you are using a pointer to a function when the function is expecting a function. If you remove the & from the 6th line, it may fix the issue.
Also, what environment are you developing in using C++?
Jason D
(3,608 Views)
Hi brianbat,
The C++ FAQ Lite has a couple of entries about this:
[33.1] Is the type of "pointer-to-member-function" different from "pointer-to-function"?
[33.2] How do I pass a pointer-to-member-function to a signal handler, X event callback, system call...
Note that the "void *callbackData" parameter is useful for passing the "this" pointer. Here's a completely untested example:
class MyClass
   int32 everyNSamplesCallback(TaskHandle taskHandle, int32 everyNsamplesEventType, uInt32 nSamples);
   void registerEveryNSamples();
int32 MyClass::everyNSamplesCallback(TaskHandle taskHandle, int32 everyNsamplesEventType, uInt32 nSamples)
   ... do whatever ...
static int32 CVICALLBACK everyNSamplesWrapper(TaskHandle taskHandle, int32 everyNsamplesEventType, uInt32 nSamples, void *callbackData)
   MyClass* obj = static_cast<MyClass*>(callbackData);
   return obj->everyNSamplesCallback(taskHandle, everyNsamplesEventType, nSamples);
void MyClass::registerEveryNSamples()
   DAQmxErrChk(DAQmxRegisterEveryNSamplesEvent(
      m_hTaskHandle, DAQmx_Val_Acquired_Into_Buffer, NI_DAQmx_SAMPLE_SIZE, /* options */ 0,
      &everyNSamplesWrapper, /* callbackData */ this));
Brad
Brad Keryan
NI R&D
(3,581 Views)
