I am gathering audio on 8 channels (PCI-MIO-16E1) and calculating 7 cross power spectra (MeasurementStudio and VB). Does NI have a dsp hardware recommendation for speeding up these cross power calculations?
You might want to call & check DSA (Dynamic Signal Analyzer) boards available by NI. I don't know the exact details but one of the boards have a processor on it and is specifically designed for sound and vibration analysis. I think that the computation is done by on-board processor.
A Rafiq
(2,974 Views)
NI offers 2 DSA (Dynamic Signal Analyzer) devices with hardware signal processing capabilities. Calculating cross-power spectra is usually considerably faster when using these devices.
One of these devices, the 4551, has two channels of analog input. It will allow you to perform one cross power calculation. The other device, the 4552, has 4 analog input channels allowing for 2 cross-power spectra. Both DSA boards offer simultaneous smapling, hardware anti-alias filtering, and 16 bits of resolution.
If speed is a major factor, one possible workaround with your hardware would be to log the time-domain data to file and perform the cross spectrum calculations later off-line.
(2,974 Views)
