I am having a problem with the Ni 5412 Vxi, doany of the gurus know abt this problem. pls mail to pvanil@yahoo.com
I am trying to run a program, and when i am running it is saying the error code 10401, and it is saying the device had been moved but we hadnt changed any thing from our previous run. and it is saying not correctly configured in measurment and automation tree.
(2,445 Views)
Hello;
The first thing you need to double check is of the board is still working properly in Measurement and Automation Explorer (MAX).
To do that, you can open MAX, right click on your board under Devices and Interfaces, and select the test resources option. If the resources test is positive, you can do the same and select the test panel option.
This is looking like the installation of the board is not proper.
Hope this helps.
Filipe A.
(2,445 Views)
Thanx for the answer.
i will be trying that way then.
(2,445 Views)
