I am looking for a simple (read very simple) vc++ example for acquiring data from an analog channel on a PCI 6221
Hello twrfte,
Welcome to the NI forums.  The examples should be installed in C:\Program Files\National Instruments\NI-DAQ\Examples\VisualC\Ai.  If they are not here, then you need to be sure that you included support for VisualC when you installed the driver. Below is some links to some resources to help you get started with basic DAQ programming. I hope this is what you are looking for
DAQ Getting Started Guide:
http://digital.ni.com/manuals.nsf/websearch/44D6FD85880DAF80862572FE0077A0AF
Field Wiring and Noise Considerations for Analog Signals:
http://zone.ni.com/devzone/cda/tut/p/id/3344
Getting Started with DAQmx
http://zone.ni.com/devzone/cda/tut/p/id/5434
National Instruments Training:
http://www.ni.com/training/
Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications
http://zone.ni.com/devzone/cda/tut/p/id/2835
Neal M.
Applications Engineering       National Instruments        www.ni.com/support
(2,793 Views)
