You can set the gain on a per channel basis by using the lower level functions. (As opposed to the easy i/o functions.) For example, look at the "SCANsingleBufSync.C" NI-DAQ shipping example that uses the SCAN_Op() function. It's gain parameter is an array of gains that will allow you to change the input limits for each channel separately.
-Russell
