I can configure a task continuous DAQmx Interactively?
I want to build a VI that you can configure how many and which channels will be use and then configure informations as max/min values, rate, samples per channel.
I know that each daqmx task can only configure 1 device, but the problem is that when i create a VI as is show in http://www.ni.com/swf/devzone/ai/ any change in the controls wont take effect, but i need to do this changes intereactively.
Message 1 of 1
(3,149 Views)
