I can't connect my module 9215 to the circuit
I have a DAQ 9191 chassis and 9215 module.
I want to connect it to the output of a circuit. How do I connect it. It has got the screw terminals for inputs but how do I connect it with my circuit.
Please Help...
(3,105 Views)
Wires from your circuit to the screw terminals would be the obvious answer. What exactly is the difficulty
(3,100 Views)
How do I connect thw wires. As in do I remove the screws and connect the wires or what.
(3,097 Views)
Accepted by topic author robotica
No. there is an opening below the screws and as you loosen a screw, you'll see a clamp like affair open. You insert a stripped end of wire in there and then tighten the screw. Give a tug on the wire to make sure it's secure.
(3,092 Views)
