05-28-2009 07:56 AM
When I wan't to export my global channels and scales, I can't select them in the window because they don't appear (see image below). I already did that with a previous release of MAX and it worked fine. What's wrong now ?
Laurent
05-28-2009 08:07 AM
05-28-2009 08:18 AM
No, it didn't works. I import a old nce file that I have, and then try to export my config. Still the same problem
Laurent
05-29-2009 09:15 AM
You have the exact issue which myself and at least one other person has already mentioned on the forums. NI has worked towards finding a solution, and they can't find it. As far as I can tell, it's broken and can't be fixed. My 8.5.1 exported fine, but 8.6.1 is broken.
If you have service support active, you need to call NI, and mention this problem.
