I don´t have DAQ Palete Function in LabVIEW after instaling DAQmx controler
Hi everyone
I had to reinstall my National Instruments software and when installing the DAQmx driver, it does not give me the option to install "NI-DAQmx Support for Labview XXXX", so I can't use the DAQmx function palette in LabVIEW.
I have insatalled the following software in the following order, which were working correctly before the issue:
- LabView 2017 SP1 (32 bit).
- NI-488.2         Ver:19.5
- NI-VISA          Ver:19.5
- NI-DAQmx      Ver: 19.5
As I could see, the compatibilities between versions are adequate. Also, in NI-MAX, I can see that my data acquisition device is working correctly (USB-6351).
I have also updated the rest of the drivers and tried to repair both LabVIEW and DAQmx through NI Package Manager.
Why is this happening? I have to install something else beforehand?
Thank you very much.
(581 Views)
You got to install the support manually. As I known, if any dependency is required, it will pop up and remind you to install.
(552 Views)
