I encounter error 200220 while testing NI ELVIS II
I am trying to test NI ELVIS II series as mentioned in the manual (namely, connecting a BNC cable between the FGEN and SCOPE CH 0 BNC and wiring FGEN an AI 0 +, and AIGND and AI 0 - on the prototyping board). When I want to run the Function Generator I get 200220 error: Device identifier is invalid.
How can I solve this problem?
(3,139 Views)
On the Function Generator window, what did you put as the device name? Is it the same as the name which appears for your ELVIS II in Measurement and Automation Explorer (MAX)?
Nathan S.
(3,133 Views)
