I have Lab VIEW 6.What software do I need to install to run USB-6008 Board.
I am a pretty beginer of the labVIEW. I have LabVIEW6 and USB-6008 multifunctio DAQ board.What software do I need to install to work with this board? In the present time I need to use the board's two analog output channels only.
Krishna
(2,715 Views)
In order to use the USB 6008, you have to install either the DAQmx or DAQmx Base driver which you also got with the card but in order to use DAQmx or DAQmx Base, you need to have at least LabVIEW 7.
(2,704 Views)
