I have a problem taking the temperature readings using LabVIEW with my SCB 68 with thermocouples. I am using PCI 6229.
When I configure the thermocouples and place them on the table in my room, they are working perfect, showing the room temperature. I am happy.
But when I touch the thermocouple the values are erroneous. That is, when I move or disturb the thermocouple it is giving our erroneous results. Like showing 50000 or -100000 degree Celsius.
Why is this? I need to put this thermocouple on my small engine surface which disturbs it obviously when I move it from the table to the engine.
Why is that very sensitive to movement?
I used different types of thermocoples.
(3,118 Views)
hgottipati,
Have you tried to checking the voltage coming out of these thermocouples when you move them?  That will help us determine if it is a problem with the thermocouples or a connection/software problem.  How are you connecting these thermocouples to the SCB68 which pins, are you using thermocouple wire etc?
This isn't a normal problem for thermocouples.
Sincerely,
Jason Daming
http://www.ni.com/support
(3,090 Views)
Hi
thanks for the reply. After a few trials now I could able to get some respectable readings even if i disturb it.
(3,085 Views)
