I'm trying to install a labview Application developed in LV 5.1 runing windows xp
I'm installing Labview 5.1 under Windows XP to be used with PCI-MIO -16XE-50 and NI-DAQ 6.9.3 to run an old aplication that was originaly developed in Windows 98.
After installing LabVIEW and ni-daq, when I place a DAQ vi in the diagram, i receive an error
"This aplication could not be initialized because NIPALU.DLL was not found. Reinstaling the application may correct the problem"
I've re-installed everything LabvIEW, NI-DAQ several times, it didn't worked.
Any help is more than welcome.
Ricardo
RKO
(2,820 Views)
Hi Ricardo
LabVIEW 5.1 does not work with Windows XP.
(2,800 Views)
I've re-installed Windows XP from scratch, then installed LabVIEW 5.1 and NI-DAQ 6.9.3. Then IT WORKED !!!
RKO
(2,793 Views)
