I need an example for stacking waveforms in onboard memory using MS Visual c for PCI-6115
I would like an example of stacking multiple acquisitions in onboard memory for the PCI-6115 card. This is sometimes referred to as "Multiple Record". It is called "Sequence Waveforms" on Lecroy Scopes. I have done this on other cards before, but not on an NI card.
The example should include a way to accept a trigger, gather x number of samples, and rearm rapidly without transferring any of the just-acquired data. This way I won't miss any trigger events. The onboard memory is sufficient to store all of the waveforms that I need. One the card has acquired n waveforms, I want to DMA them into RAM.
Thanks to anyone that can help!
If you need any more specifics, just le
t me know and I'll post them.
Message 1 of 1
(2,548 Views)
