I need help to select the PXI card and supporting hardware to test the 0-25mA output signal from our device.
We have the product which is generating the 0-25mA output current.We are planning to test it from the NI.
We have NI PXI 6259 card (AI).would you please help us, how to test it 0-25mA output current with 6259 card?
(2,579 Views)
You can just use a 500 Ohm resistor in parallel with your signal.  I would also add a buffer circuit to protect your DAQ.  Or you can do a quick search for isolated converters.
(2,551 Views)
If this will be a product quality related measurement, you have to look at uncertainties and traceability (calibrations) ...
For a quick and dirty check any 500 Ohm resistor from (or underneath 😉 ) the bench will do it (0.5W better 1W) , otherwise you have to look for a stable low tempco resistor....
Greetings from Germany
Henrik
LV since v3.1
(2,540 Views)
