04-10-2008 12:48 PM
04-10-2008 01:01 PM
Hello Robots,
The latest version of the driver for the USB-6009 is NI-DAQmx 8.7.1. If you're using a version of LabVIEW newer than 7.1 then this is the version you want. If you have an older version of LabVIEW then you'll need to check this KnowlegeBase article to find the correct version: NI-DAQ & LabVIEW Version Compatibility (for Windows)
Once you know what version you need you can go to www.ni.com/download and click on Drivers and Updates to search for the correct driver. After you download and install this driver Windows should be able to find the drivers and correctly identify your card.
I hope this helps, and have a great day.
Cheers,
06-29-2012 01:16 AM
please
06-29-2012 09:27 AM
@wewer wrote:
please
and thank you
05-31-2022 03:33 PM
Hello, how are you?
I recently regained an old LabVIEW 12 license that I acquired as a student license when I purchased a DAQ-6009.
In 2016 I had the CD with the installers and drivers for the DAQ but I lost them.
I asked NI for version 12 installers, but I could only install LabVIEW. Do you know if there is a possibility to download the drivers to use the DAQ from LabVIEW?
Thanks a lot
05-31-2022 05:15 PM
I think it was in 2014 that NI decided to make the driver versions follow the year. So you see a jump from 9.9 to 14.0 in the downloads. However, I would use DAQmx 15.5.1, which is the last version of DAQmx that supports LabVIEW 2012.
