I receive "Error 11000 occured at AO check"
While trying to send signals to the analog out of my MIO daq. Test panels show no malfunctions whatsoever
(2,679 Views)
Greetings,
I'm not sure I understand what your question is. You state everything is working fine and showing no malfunctions.
If you do have a question, please give a little more detail on what you are trying to do, what DAQ card you have, what programming language you are using (LabVIEW, LabWindows/CVI, Visual C++, Visual Basic, etc.).
Justin
(2,679 Views)
Thanks for your answer, Justin
But I already solved the problem myself.
The problem was an error in my LABview 5.1 VI, that caused the value to be sent to the 'analogue out' of my DAQ to be too large.
This caused a very messy error message beginning with 'Error 11000'.
I still don't know what was going on, but the problem is solved.
Kind regards,
Joris
(2,679 Views)
