I search a VI to generate CC voltage (0-10V) with a daq PCI 6221, I have LV 8.5
I search a VI which permit to send a constant signal (voltage) with a cursor for example...
I want to use the Daq Express to generate this signal but there is not continuous voltage only (sinusoïdal, etc...), I don't know how perform to do this correctly.
Thank you
(3,322 Views)
What's so hard? With the DAQ Assistant, you simply have to select one sample on demand and wire a scalar to the input. If you wanted to use the DAQmx Function, select DAQmx Write - single channel single sample.
(3,321 Views)
Yes I try this but an error message appears: "Measurement can't start, buffer too small, increase the buffer" I don't know how increase it...
This is my parameters, I think there is an error but I don't know where I am novice.
generation mode: continuous
freq = 1k Hz
sample rate: 100
(3,317 Views)
Why did you use those parameters instead of the one I said to use? I will repeat - 1 Sample (On Demand). Doing continuous generation and specifying a sample rate/number of samples for a dc signal is just silly.
See Getting Started With DAQmx.
(3,308 Views)
