I want to acquire data from port which connected with USB port
(4,453 Views)
Please be specific. What device is connected to the port? This board is for NI data acquisition devices. Can we assume that you are using one of those? If so, you would first install the DAQmx driver. After that, it depends on what programming language you are planning on using.
(4,452 Views)
 I actually want  to acquire data from Powersupply which is connected through USB port., what procedure can I adopt in LabVIEW environment
(4,355 Views)
What power supply (make and model)?  Some instruments will show up as serial ports when connected via USB.  Does yours do this?
(4,352 Views)
Why is it necessary to keep asking you to provide some useful information? Your responses are inadequate. Please learn how to phrase a question.
(4,342 Views)
