I want to connect 4-20mA level transmitter to CB 68LP device
I have level transmitter having 4-20 mA output and CB 68LP device with ribbon cable.
I Want to get level data on my pc having Labview for measurment and analysis
Can anybody having solution for this ?
(3,298 Views)
Not enough information.
What is the CB 68LP connected to?  You need to have a DAQ card connected to the CB 68LP.
Most likely you will have an analog input channel that you can use.  But to use a voltage channel with a mA device you will need a resistor across the channel.  If you use a 250 ohm resistor 4 mA = 1 volt and 20 mA = 5 volts.
(3,286 Views)
I also have current to voltage convetor with me
(3,276 Views)
(3,274 Views)
Then connect the voltage output to your CB-68LP.  When you set the channel up in MAX there will be a tab that shows you were to connect the wires for the specific channel.
(3,271 Views)
