I want to increse out volt in 20sec.
Hi.
I use .Net c# and usb-6001.
I want to use the AO increse without timer.
How can i use it?
example:
  1. Target
    1. 0 to 10V output during 20sec.
  2. Now
    1. use window timer in c#, increse 0.05V / 0.1sec
  3. Problem
    1. It works stair shape.
    2. Window timer is not correct. (error ± 10ms)
(527 Views)
You can use the hardware-timed analog output feature to generate an array of ramp signals.
This hardware-timed technique is the right way to guarantee you the ramp rate as long as the external device doesn't load the signal beyond the drive capability.
Santhosh
Soliton Technologies
(502 Views)
