I want to measure three phase ac parameters such as voltage, current power factor, etc which daq device will serve the purpose.
I want to measure three phase ac parameters such as voltage, current power factor, etc which daq device will serve the purpose at lowest cost.
Message 1 of 14
(4,887 Views)
It depends on what you will be doing with the data, how fast you need updates, and how much accuracy and resolution is required.
In any case the transducers necessary to change from line voltages and currents to values suitable (and safe) for measurement with DAQ devices may cost more than the DAQ device itself.
Lynn
Message 2 of 14
(4,878 Views)
What can be the safe limit for the DAq Device...
Message 3 of 14
(4,864 Views)
Most DAQ devices have +/-10 V input ranges with respect to ground.  There are specialty devices with other ranges of course.
You need to consider not only the voltage ranges, but also safety isolation and transients which often occur in power systems.
Lynn
Message 4 of 14
(4,859 Views)
What device will u suggest for 3 phase measurements
Message 5 of 14
(4,854 Views)
Infact I am a university student of bachelors and i do not know much about the labview. Some one told me to do this project. Do you think that it can be done in a low range of money(max 200 $). kindly help me so I can think of any other way if it is not possible. Thanks
Message 6 of 14
(4,851 Views)
There are very few if any DAQ devices which cost less than $200. Suitable potential and current transformers or other transducers are not inexpensive either.
Does your university electrical laboratory have any transformers or transducers you can use?
It sounds as though you have little experience with power systems. THE VOLTAGES AND CURRENTS USED IN THREE-PHASE POWER SYSTEMS ARE DANGEROUS! CONTACT WITH THESE CIRCUITS CAN RESULT IN DEATH OR SERIOUS INJURY. INCORRECTLY CONNECTED OR UNSUITABLE EQUIPMENT MAY BE DAMAGED OR DESTOYED! If you do not have training in the safe use of such equipment, get training before you attempt to do any measurements.
Lynn
Message 7 of 14
(4,846 Views)
You asked about alternatives.  What is the purpose of these measurements? What will you do with the data after you get it? Could you do some thing with a single phase system?
Lynn
Message 8 of 14
(4,845 Views)
I am thinking to do this as my project for our electrical machines laboratory.
Message 9 of 14
(4,840 Views)
Check with the person in charge of the laboratory. A machines laboratory should have transformers and possibly other transducers.  Find out what is available. The person in charge may also know of other resources at the university or through local companies who would assist.
Lynn
Message 10 of 14
(4,838 Views)
